charging port failure loose
Where can I get my charge port micro soldered
I need to recommend some one to micro solder
The charge port will not allow a charge
Its honestly cheaper to buy a new charge port than to fix and existing one.
No, that is not correct. Fixing the broken contacts does not need the removal and replacement of the micro USB charging port and will not cost anything. See my post below.
In the HP Chrome book that I have, the microUSB port was partially loose. The port has two parts, one is the steel frame that is soldered to the motherboard at four points around the edges , and the second is the plastic insert that holds the five USB contacts that are soldered at the rear of the port to the motherboard. In my case, the insert broke off all five contacts and was actually sliding inside the frame.
My solution was to push the insert into its correct position (contacts aligned with solder points on motherboard), then with a wooden toothpick moisten with Super Glue, dab at all external spots where the insert touched the frame (don’t get any inside the microUSB connector!). Finally, using a conical pointed soldering tip, resolder the five contacts and check continuity. You cab add more Super Glue after all the contacts are verified to prevent future plug insertions from moving the insert and breaking the solder points again in the future.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 364
