Dropped by mistake phone in toilett.
Hi...
As stated, my S6 Edge has taken a bath in the toilett.
The phone was not starting for 1 day.
Now the phone is starting only then battery charger is connected.
The phone say that the battery is 100 % charged.
Then I disconnect the charger then running, it just dies.
Sometimes when I try to boot I have to do Volume Down + Hometab + On buttom and then choose cansel then screen boots up. Then the phone boot up.
I have done a faktory reset.
I wonder, which parts is most likely to be changed?
Regards
A clumsy person :(
Update (07/10/2016)
Hi again...
I have now cleaned the phone inside and changed battery and charger port.
Problem still exist.
Any other solution I might try?
/NBonline
Update (07/16/2016)
Hi again...
Tested with disconnecting the battery from motherboard for 6 hours .
When i connected it again I could start the phone without charger and it show probably the right battery status.
After abaout 6 hour the phone went dead again. It worked perfeclty until then.
Time to test it again and see if it get any better.
/NBonline
4 commentaires
Thanks for quick responce!
I will take it appart and clean as you advised.
Do you think anything else appart from battery should be replaced?
/NBonline
par Niclas Brorsson
Not until you know what you have after you clean it and replace the battery. That is truly only the beginning of the trouble shooting. It give you a clean starting point.
par oldturkey03
Ok, thanks again for fast answer. I will do a cleaning and replace battery, then will se what happens.
par Niclas Brorsson
Hi again...
/NBonline
par Niclas Brorsson
