Controller Port 1 doesent work
Hey Everyone,
I got a Dreamcast from Ebay, but the Controllerport A/1 doesent work. All the other, B/C/D works perfectly.
I hope you can help me
Hey Everyone,
This guide would be the easiest, if you don't want to solder it
Remplacement du port du contrôleur ed la Sega Dreamcast
This guide would use a little more work, but you could individually change out one controller port
Réparation des ports manette de la Sega Dreamcast
Also found this on eBay
Tutoriel
Difficulté :
Difficile
10 - 20 minutes
Tutoriel
Difficulté :
Modérée
15 - 25 minutes
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 1,425
3 commentaires
Do you know how to solder? If you don't, your best bet will be to purchase a replacement controller board off ebay and simply swap out the part.
par Ben Eccles
yes i can solder, but why?
i read a lot of the problem on the internet, but that is always all controller prots, not only one. so i think the problme withe the fuse coulnd't be
par thunderblrd
The reason I ask is that controller port board on the Dreamcast is among one of the more friendly parts for soldering, since all the components are through-hole. I would do a continuity test on the fuse, just to rule it out as a problem.
par Ben Eccles
