BenQ DVD drive won't open when metal casing is fully closed?
When the metal casing of my BenQ DVD drive is fully closed, it won't eject. If I remove the upper casing OR pull the upper casing slightly up, drive opens just fine.
To clarify, I do mean the metal casing of the DVD drive itself, not the entire console casing.
Any suggestions? Thanks in advance.
Update
Trying again.. any solutions guys?
I'm confused. Is the DVD casing bent in front of the tray or is the tray somehow misaligned so that it runs into the case. For physical issues like this, pictures are extremely helpful.
par Alex Jansen
No, it doesn't appear to be damaged in any way. Here's a link to some pictures http://picasaweb.google.com/jenavii/Unti...
I have an idea of what I think may be the problem and I'll try my best to explain. It could be the washer shaped magnet (4th pic) and the plastic piece (w/ magnet on the top casing, 5th pic) that hold the disc in place. From watching the drive open/close with out the top casing, I can see that the area with the washer shaped magnet and laser drop down.
I'm assuming that's to releases the upper plastic piece, so that it can eject properly? I'm thinking that when the casing is fully closed, the hold of the magnets is so strong, that it will not allow that are to drop down, so its not able to eject. What do you think?
par jenavii
