Cant start phone setup wont connect to wifi
I can't get my phone to connect to WiFi.
Have you a hard restart of the phone (hold down the power button and the home button simultaneously until 2 seconds after the apple logo appears) Have the phone connected to your computer with a cable while doing this and have iTunes opened. If this is successful backup your phone immediately with a local backup and should allow you to wipe and restore IOS (fixing any corrupt parts of the OS) and and your apps. If this fails you may have a hardware failure, but you should still be able to use the phone if the WiFi component has failed, just disable the WiFi syncing when you restore IOS.
put it in the freezer for about 10 minuts. fixes it for a short time. need to make a longer better repair.
Hey Dessie, I use to have this issue too and what I did was turn off Wi-Fi and then turn it on. If the problem persists I forget network and then connect again. The next option you can do is to restart your modem and router. I hope this helps. You can read the full instructions here: http://www.technobezz.com/iphone-wont-co...
I also have an iPhone 4s which I use on a BOSE speaker port in my makeshift garage gym. I had a similar issue with WIFI connection. These are the 3 solutions or reasons I’ve read in researching the issue. #2 worked for me.
1) WIFI is is actually grayed out for some users. Solution: Reset Network Settings on your iPhone
2) Simply turn off / on your home router. I first troubleshooted using a separate hotspot wifi device I use for work. I successfully connected to it. That’s a good sign. I then turned my home router off/on and proceeded to manually connect my iPhone to my problem home wifi. It worked.
3) There are some articles/ posts/ youtube videos that indicate it may be a hardware issue. “Put it in the freezer…” etc. or actually open your device and solder parts. I wouldn’t do this unless its an absolute last resort. Proceed with extreme caution.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 121
1 commentaire
This is likely the cause of a bad wifi chip, which is very difficult and expensive to fix, but the good news is that you should be able to activate with itunes and sideload apps.
par echow2001
