Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Samsung Galaxy J1, sorti en janvier 2015, numéro de modèle SM-J100VPP/SM-J100H.
Why can't my phone boot up?
It all started when my phone was charging and it was rather lagging, so I proceeded to reboot my phone. However, i could not start up my phone again and the phone was still on the Samsung screen and nothing happened! I am unable to boot up my phone. Someone please help as soon as you can thanks!
Répondu ! Afficher la réponse J'ai le même problème
Indice 4
Ajouter un commentaire
2 Réponses
Solution retenue
That is a software issue either one of these should work. If you don't want to lose data flash downloaded samsung firmware from sammobile with the matching model number of your phone located in the battery compartment on a label.
Use Odin with the phone booted into download mode and plugged in. Instructions on how to use Odin and flash firmware on to phone are on every download page of firmware from sammobile.
If you don't need to backup data use Samsung kies with firmware upgrade and initialization OR turn the phone off by taking out the battery for a few seconds and putting it back in.
Then hold the power, volume up and home buttons until the white Samsung splash text pops up and immediately stop holding the power button and keep holding volume up and home.
Then it will boot into the recovery menu. And you can use the power button to select and vol up and down to select in the menu. Select wipe data factory reset and reboot phone from recovery mode.
Indice 4
2 commentaires:
When ive done that the wifi appear and i cant log in
par
I'm not able to do any of the suggestions:-
Have removed the battery for 8+ minutes;
Won't boot up;
Holding several buttons down doesn't start up;
Screen remains black so not even able to determine whether battery is flat;
The last time the phone was on the indication was that battery was fully charged?
I really would appreciate some assistance.
Thank you.
par
Its FRP lock. either you had to enter the existing Gmail id or you can use FRP bypass techniques
Indice 1
3 commentaires:
Yeah. There are also people that offer frp lock removal using flash / programming / unlock boxes like frp which is sometimes required if bypass techniques without that do not work.
While I have the tools to do this. I don't offer this as a service as its kinda illegal to me but I could be wrong.
par
Can someone help me please, after i flash my phone using Odin, it wont start up, i only seen a black screen even if i charged it stil no logo, i dont know if its charging or not there is no pop up on the screen please help its Galaxy j1, please pm me @successemmanuel458@gmail.com
par
when i press and hold volume -,power key..for recovery mode
my phone was normaly start...help...please
and i can't update my phone
par
Ajouter une réponse
Brendan Ng sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 34
Total : 6,788
