Aller au contenu principal
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
20 questions Voir tout
Double fan on a grand am gt
I have a double fan and only one is working. I belive it is the one that cools the A/C cause it quit working to
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
If your referring to the 2 fans on the rad one comes on at a certain temp and the other comes on when the temp reaches full operating temp. you can test it to make sure it works by wiring it direct to the battery. It may be a relay if its not working or the sensor may not be working to send the signal to turn it on. Do you know why the air isn't working ? Did the two events happen at the same time ? If you blew the relay for the air then it could also have taken out the fan or they may actually run off the same relay . One last question does the car overheat because of the fan not running or is it running in normal operating temps?
Indice 2
Ajouter une réponse
Tammy sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 113
