Aller au contenu principal
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
20 questions Voir tout
Machine has lost its prime
lost prime on pump. Machine sat for a while not being used. Doesn't flow water thru..
Répondu ! Afficher la réponse J'ai le même problème
Indice 14
12 commentaires
The Starbucks Barista RARE Royal Blue Coffee & Espresso Maker I Just Picked up Was Not Working. After Reading Your Comments I used a Turkey Baster And Thanks To All OF YOU I Can Have Great Coffee
par
My machine is half primed. In other words the pump get water into the porta filter section but I can't get the steam wand to steam...it appears there are 2 tubes that need to have water flowing through them but it is obviously only getting water into the porta filter section. Any hints?
par
If water is flowing from the brew head but not the steam wand, check the tip of the steam wand to ensure it isn't plugged. The steam wand feeds directly from the boiler so if the boiler has water it should too.
par
I have an old Krups that had sat for years. It doesn't have a tube in the water tank. It has a entry at the bottom of the tank. What should I do to prime it?
par
Paul your Krups likely has little in common with this machine. You might be better served posting your question under one of the Krups machines featured on this site.
par
Voir 7 commentaires en plus
Ajouter un commentaire
7 Réponses
Solution retenue
You can use a turkey baster/ear bulb/etc to force-prime the pump; often they get airlocked when sitting for a long time. Fill the bulb with water and fit it into the water intake hose, then with the pump running squeeze the bulb to force the water in. As soon as the water starts to flow easily turn the pump off, put the hose back into the water tank and continue priming.
Indice 18
36 commentaires:
Mine had been in storage for 3 years. I used the bulb filled with water to get my pump primed.
Thanks Henry !
par
Eureeka! Everyone in the family tried in vain to fix this machine, with no luck. I had it boxed up last Christmas to send to Vancouver repair person and just yesterday 10/28/2013 I researched again - bought a $.99 suction bulb and it worked!! Thank you!!!
par
Opening the steam wand did not work for me; and I was not able to force water into the pump hoses from the exterior. I had to disassemble the bottom (in my case only 4 screws) to access the water tubes. Then using a basting syringe I forced water into both tubes and because I had heated the unit before I could hear the water hit the hot tank inside. I reassembled and made a great cappuccino!
par
the bulb worked! i forced water up the hose and now it's working again! thanks...one problem though...water isn't that hot :O(
par
It worked! Yippee! I surely thought it was broken.....good friend gave me her old machine and it had been sitting for about a year and it flushed it with a tiny syringe and its working great now! Thanks!
par
Voir 31 commentaires en plus
Guys and Gals, just follow the directions given by Starbucks: the approved and simple method for priming the pump dies not require turkey basters or ANY tools. Turn the machine on but leave brew and steam switches on right OFF. Place a cup under the steaming wand. Open t he steaming valve. Now, although we did not heat the boiler for steam, the wand has this second function, namely priming the pump. When the valve is opened but the boiler is not heated for steaming, the pump kicks on and primes the pump. When the water from the wand is flowing in a continuous stream (3-5 seconds), shut the steam valve. You may now heat the water to steam or brew.
Indice 11
10 commentaires:
Yes, this is the correct procedure to follow when the machine is new or has had it's boiler otherwise purposefully emptied. However, when the machine has sat unused for a long time the pump can become dry-locked and then it requires either water under pressure (via a turkey baster or similar tool) or compressed air to be forced through it to began working properly again.
par
Mine sat for 5 yrs, pulled it out to use it and had no prime. The pump worked, and i took everything apart including the one way valve on the pump, reassembled and still had no prime. I used this method above and it worked perfect.
par
My machine is over 7 years old and I accidentally ran the tank out of water and needed to reprime the pump. I followed these instructions and the pump was primed and is working well again.
I tried priming the pump using a turkey baster but could not prime the pump. I will use the steamer from now on. Great machine and very simple to operate. Hope to get 7 more years out of it.
par
This worked for me. Thank you! (I'd left the machine running for 5 minutes with no water in the tank and couldn't get it to pump afterward until I tried this.)
par
Thanks anami!!! spent an hour trying the baster thing and nothing. finally found your answer and worked in less than a minute! Muchas gracias, now my co-workers in the VA can try Cuban coffee for the first time!
par
Voir 5 commentaires en plus
I found that if the machine has sat for a while (years in my case) just using the steam wand WILL NOT WORK. I followed the suggestion of forcing water into the pick up tube that sucks out of the water tank. I used one of those injectors (like a big hypodermic) for flavoring meat. Worked right away and I’m pulling pretty good shots already. Good thing since my Rancilio Sylvia just bit the dust after 20+ years. Got the Starbucks machine a long time ago at a thrift store for $50.00. Oh did I mention it was virtually brand new? Thank you IFIXIT people!
Indice 1
Works with Graef ES. I've usually had to wait an hour or more when it's accidentally run dry. This time I was up and running only a few minutes later. First time I've used the steam tube.
Indice 0
Hello! I hope i can post a question.. So mine won't prime either but it is making a loud humming clanking sound when I turn the wand to prime... Will turkey baster work for my unit or do I have a broken part?
Indice 0
2 commentaires:
Janet, if your machine has a descale light then it isn't the machine being discussed here, and I'm afraid most of the advice won't apply.
par
What if you go though this bulb manual priming method and it won’t hold a prime more than three days? Bad pump seal? Replace the pump?
par
I’ve used both the manufacturer’s priming method (steam wand when machine is cold) AND the turkey baster method with no luck. Compressed air? Help! Bought this (used) for a friend and the owner said he used it successfully 6 months ago!
Indice 0
3 commentaires:
I have the same problem!! WhT now??
par
My steam wand works and steams milk. Why won’t it pull a shot?
par
I read through this on other forums to try to understand this problem. Apparently there is a tiny ball of plastic that serves as a switch between the steamer and the espresso feed. When the machine is sitting for a long time, that can become stuck in the last position it was used. I thought it might be possible to use vinegar to unstick the ball, so I put vinegar water in the holding tank, ran some water through the steamer so there was vinegar in the junction chamber and let it sit. When I tried it a week later it worked flawlessly.
par
Baster did not work for me. I needed remove the cover and elevate the syphon tube above the pump. Removed the filter and filled the tube with water and massaged the tube to release air bubbles from the pump. Filled the tube twice. When massaging, squeeze as much of the tube as you can to create enough suction to draught out air bubbles. I used at least six fingers.
Indice 0
Ajouter une réponse
Allen Bickle sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 29
30 derniers jours : 122
Total : 55,900
