First check your main breaker box and reset the circuit breaker. Have the machine unplugged for 5 minutes when doing this. Then plug it back in. I suspect a short.
UPDATE
Cause 1
User Control and Display Board
To determine if the user control and display board is defective, try pressing the buttons on the control panel. If some of the buttons work, but others do not work, the control and display board might need to be replaced. Additionally, if the display is not working, check the power to the user control and display board. If the user control and display board has power, but it isn’t working, replace it.
Cause 2
Timer
The timer is frequently misdiagnosed—before replacing the timer, first check all of the more commonly defective parts. To determine if the timer is defective, consult your washer’s wiring diagram and use a multimeter to test the timer for continuity.
Cause 3
Line Fuse
The line fuse blows if the washer circuits are overloaded. If the line fuse blows, the washer won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. Check for shorted out components such as the wires, motor, or drain pump. If you don’t resolve the underlying issue, the new fuse will blow too.
UPDATE 7/12/18
Cause 4
Thermal Fuse
If the washer overheats, the thermal fuse will blow. If the line fuse blows, the washer won’t start. To determine if the thermal fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. If you don’t resolve the underlying issue, the new fuse will blow too.
Cause 5
Main Control Board
The main control board might be defective. However, the main control board is rarely at fault for this symptom. Before replacing the main control board, first check all of the more commonly defective parts.
Cause 6
Incoming Power Problem
The electrical outlet may not be getting power. To determine if the outlet is getting power, try plugging something else into the outlet. If the outlet is not getting power, check the home circuit breakers or fuses.
Cause 7
Power Cord
First ensure that power is getting to the electrical outlet. If the electrical outlet is receiving power, but the washer won’t start, the power cord might be defective. However, this is very rare. To determine if the power cord is defective, use a multimeter to test it for the cord for power. If the power cord is not getting power, replace it.
Parts
Cause 8
Door Lock
The door lock secures the washer door shut during operation. Once the washer door is closed, the washer can begin operating. If the washer door is not latched shut, the door switch will prevent the washer from operating. If the door lock is defective, the washer will not spin or start. The door lock can fail either mechanically or electrically. Inspect the door lock for damage. If the door lock is damaged or does not latch properly, replace it. To determine if the door lock has failed electrically, consult your washer’s wiring diagram and use a multimeter to test each of the door lock switches for continuity.
A voté
Annuler
Indice
3
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
12 commentaires
Mine starts and runs for a few minutes then displays power failure. I reset it several times and still does the same this washer is less than 90 days old.
par john smutny
It's a 3670 LG front loader
par john smutny
John mines doing the same thing. I am still looking for a solution. Have you resolved it?
par Andrea
Mine did the exact same thing and I have work clothes inside and no clue how to get door unlocked!
par cristal_worwa
This happened to me this morning and my clothes are also locked in! Any solutions??
par soccershank
Voir 7 commentaires en plus
