Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Roomba 650 est un aspirateur robot de quatrième génération sorti par iRobot en août 2012. Cet appareil fonctionne en mains libres et est programmé pour nettoyer nos maisons. Avec très peu de manipulations manuelles nécessaires, ce robot a révolutionné le nettoyage domestique.
Roomba ignores virtual walls
Roomba 650 ignores virtual wall, but docks OK. I have the VWs that have a two position switch - auto/off.
I have tried new batteries in the VWs and even changed the sensor in the Roomba.
When switched on the VWs blink about every 8 seconds. I have two of them. Could they both be bad?
Update (08/08/2016)
Yes, VW = virtual wall. The VWs that I have do not have a power button that can be pressed down. They are slide switches and have two settings - OFF and AUTO.
I see no other way to reset them.
Répondre à cette question J'ai le même problème
Indice 1
2 commentaires:
@autolab VWs=virtual walls? When you changed or removed the batteries did you hold down the power button for more than five seconds to reset the wall?
par
I have a similar problem. Something seems loose in the virtual wall (I have a the Dual mode version).
There's no obvious way to disassemble it and I already tried changing the batteries and there was no improvement
par
Ajouter un commentaire
1 Réponse
I have the same problem. I think is a led problem. If you have an other one, please record a video with the phone and look it you see the light of the led.
thanks.
Indice 0
Ajouter une réponse
Wes Pike sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 23
Total : 2,045
