Aller au contenu principal
Repair and disassembly guides for Magellan GPS devices.
GPS says "Resource not found. Please connect..."
Hi.
I have a Magellan smart GPS 5390.
It's probably off warranty but it has worked reasonably well until my last update attempt. First, smartgps Eco displayed a message that my unit couldn't be updated since there wasn't enough space. So I deleted some files even though I had well over a gig of space remaining. I was then able to complete the full update to my unit. However, when I disconnected the unit from my computer, the message displayed on the unit was, "Resource not found. Please connect smartgps to smartgps Eco and update your device." I again connect my device to smartgps Eco but theres no update to update the smart GPS with.
Also, live chat and telephone support are non existent.
Has anyone else had this issue and or have a solution to this problem?
Thanks
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Update (12/30/2017)
After installing new software or map updates to your Magellan GPS, you'll need to reset the device. A reset ensures that you will be able to access the updated data correctly and without system errors. Resetting can also be useful as a basic troubleshooting step if the device is malfunctioning. Your Magellan GPS has a hardware reset button that you can easily access. Various Magellan GPS devices come equipped with three different kinds of reset buttons.
Update (12/30/2017)
Pinhole Button
1. Locate the small hole labeled "Reset" on your Magellan GPS. Depending on the model, it is located on the bottom, or the left or right side of the unit.
2. Insert a paper clip into the hole and push the reset button until the unit turns off. You should hold it for about 10 seconds.
Press the "Power" button to turn the unit on. You can now access the updated maps and other information using the GPS in the usual manner.
Slide Switch
1. Slide the button from "On" to "Off."
2. Hold the button in the "Off" position for eight seconds.
3. Release the button to reset the unit.
Reset Switch
1. Slide the switch into the "Reset" position.
2. Hold it for eight seconds.
Indice -1
8 commentaires:
This is my fifth model. Either use your phone or get used to having to replace them.
par
Or fix them @j0vian
par
Dont think I haven't tried brother...
par
what was the issue and what type of phone was it?
par
Were talking about Magellan gps's
par
Voir 3 commentaires en plus
Ajouter une réponse
johnsuijuris sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 1,023
