HP laptop overheats and shuts down.
My HP G72 laptop overheats and turns itself off. What are the possible causes? I have taken it apart and cleaned it completely inside. Very small amount of dirt and the fan is working.
5 commentaires
Blow some compressed air into the fan duct, you"ll be suprised how much dust comes out. it worked for me :).
par magnusvir
Technician repaired my laptop for the same overheating as I also have a G72, the fan now works but the computer does not. Can anyone help?
par david_ogun
Can you tell me all the information about the problem?
par Jonas A.
Does the computer turn on but with a black screen?
par Jonas A.
Hi Thank you everyone for commenting. I do not have the laptop any more. It would tun on like it normally should and everything would work perfectly for a while, but after some time whether I used it or it sat idle it would just shut down for no reason what so ever. When I took it apart the fan worked fine and was clean because I would blow compressed air into all the open vents and the fan area every month or so. Also I always used the laptop on a hard surface. Thanks again.
par Vincent Donatacci
