My laptop overheat and cannot swith on
when i press botton it shows a light then off.
Sounds like your ram is inserted incorrectly. You should remove it then put it back. You can do this by inscrewing the two screws from the middle panel, and the ram will be one or two cards about 3 1/2 inches long. Push off the clips on both sides of the ram, then tilt up and pull out. If it is put in incorrectly, removing may take some effort.
Once removed, put back in by firmly pressing in to the slot at about a 45° angle, then tilt down till the clips clip on. I hope this helps. If it doesn't, I can put a video in to show you how to do it.
If it actually overheated, a new processor is about $19. You can get this:
Intel Cpu Pentium Mobile T7200 2.0Ghz Fsb667Mhz 4Mb Fcpga6 Core 2 Duo Tray (copy this to Amazon search bar) for 15 dollars + $4 shipping, but I must warn you, I haven't bought from this seller, but it gets good reviews.
If the ram overheated, new ram will cost about 20 bucks.
Any ddr2 SODIMM ram will work, but I recommend getting 4GB. Amazon.com has 4GB of A-tech ram for 20.99. That is what I will be getting.
try to check your pan. in my experience some of my repair like this is because the pan is not working.
What is the pan?
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 90
