Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tablette haute performance commercialisée par Apple le 11 novembre 2015. Modèle A1584.
Apple Pencil not working after screen replacement
Hi,
I've replaced a cracked lcd/digitizer assembly on an iPad Pro 12.9" device and the client says the apple pencil doesnt work with the new screen.
Anyone else experience the same fault?
Répondu ! Afficher la réponse J'ai le même problème
Indice 4
Ajouter un commentaire
4 Réponses
Solution retenue
The Problem was a faulty screen, replaced the screen with a new one and pencil is working perfect.
Indice 4
1 commentaire:
So the Apple Pencil will work with a new lcd that isn’t from Apple?? I have the 6th gen
par
have you tried re-pairing it? I assume each screen has a unique identifier in it. It would kinda, almost make sense that re-pairing would fix it.
Indice 0
1 commentaire:
The client informed us the pen doesn't work, however it does but there dead zones on certain areas on the screen.
I'm going to try a new screen, will update when done.
par
Installed a new digitizer and everything tested fine. During final assembly, backlight connector came off daughter board. Didn't realize this until it booted up. Thought a backlight chip maybe had been fried. Relieved to see that it was just a connector. After powering off and rechecking all connections. Started the unit up and now zero touch. Solder job was perfect. At a loss as to what the issue is now. Very little information out there on this.
Indice 0
1 commentaire:
Jeff were you able to solve this? Same thing happened to me. Bad screen maybe ?
par
Apparently when you have an Apple Pencil in the box without being charged for a prolonged period of time it loses it functionality and no longer pairs with the device. The apple store is charging me $79.99 for a replacement unit which is a not terrible but what a shame I paid that on eBay for a defective unit. Wish I would have bought it in the apple store the first time.
Indice 0
Ajouter une réponse
Ryan Veldsman sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 28
Total : 10,404
