Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tablette de 0,622 kg avec un écran de 10,8 pouces et une béquille à 3 positions, mise sur le marché par Microsoft le 5 mai 2015. Numéro de modèle : 1645.
LCD Connector is damaged, help!
Hey all,
The connector where the LCD plugs in on my surface 3 was damaged during a screen replacement. The issue is I dont know what the part is called or where to purchase a new one.
Please help me
Update (10/06/2016)
This is the connector in question. This is on the main logic board and the LCD flex plugs into it. The black piece that clamps down on the flex is gone and there is a missing pin.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
4 commentaires
Is it on the LCD or the logic board?
par
The connector on the board was damaged in case that wasnt clear.
par
[image|907316]
par
Mike check the update. Looks to be a internal 35 pin logic board LCD connector.
par
Ajouter un commentaire
4 Réponses
Solution retenue
Mike, if you can post a picture of damaged connector, it would be a big help to ifixit , I believe the connector is the mother board ribbon connector. Check the attached link and see if it is the motherboard connector, Good luck.
Changement écran Microsoft Surface 3
Update (10/06/2016)
Mike, Looks to be a internal 35 pin logic board LCD connector. Hope the link is what you want, you can also try a search yourself for (35 pin lcd connector)
https://www.aliexpress.com/item-img/20-P...
Indice 1
1 commentaire:
Posted a picture below showing the connector.
par
Mine too damaged, are you sure it's 35 pin connector at AliExpress
Indice 0
I don’t think the above connector from Aliexpress is correct. Looking into it it seems to use the same connector that is on the Samsung Galaxy Note 4 2014. It is actually a 70 pin connector not 35 because there are pins on both sides. You might be able to buy a replacement off eBay or Aliexpress.
Below is the link to the connector on Aliexpress.
FPC Connector From Aliexpress
Indice 0
Did anyone ever get anywhere with this??
Indice 0
Ajouter une réponse
Mike Smith sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 16
Total : 2,457
