Aller au contenu principal
Repair guides and support for electric and stove-top kettles.
Questions au sujet de 41 Voir tout
Whats the technical name for the silicon gasket inside the kettle?
There is a circle rubber strip that goes around the stainless steel plate which heats up. I knows its used to make it a water proof seal and support the plate but what is the actual technical name for it. I tried searching everywhere.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
nabeel, I believe it may be the kettles base to element insulator or base sealing ring in question. You may have to call the manufacturer for this info. directly, as different manufacturers use different names for parts.
Check the attached link for more info., Good luck.
https://www.google.com/patents/CN2033747...
http://www.explainthatstuff.com/how-elec...
Indice 2
3 commentaires:
thanks for answering but i still need to know the actual technical name for it, there is defiantly another name used for the actual process or the part itself which i cant find. The pages above i have come across when searching.
par
nabeeljan, you may have to call the manufacturer for this info. directly, as different manufacturers use different names for parts.
par
will do thanks.
par
Ajouter une réponse
nabeeljan sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 14
Total : 715
