Fuel not getting to the engine
My 1999 Saturn SL1 stalled while I was driving a few times and each time I would have to wait while before it would start again then the day came it stalled then never started again.
I replaced the Electric Fuel Pump, Fuel Filter, Electric Fuel Pump Relay, Battery and cleaned the Carburetor.
Still won't start, so a friend and I tried Starter Fluid Spray. It did a rough start and idle as long as he would spray then stall when he stop. It would not start on its own only with the spray.
So we're stuck. No Fuel Getting To Engine. Please help us.
Doing everything old school way, other then the internet.
2 commentaires
leggs367 you said you "cleaned the Carburetor" the Saturn uses TBI and not a carb unless this was somehow converted. Have you checked the crankshaft position sensor ? Of course you did check the fuses.....ECTS are a common failure on this model. something to look into
par oldturkey03
Try checking the fuel pressure sensor as well. Mine done the same thing
par Shawna Hall
