Aller au contenu principal
Question close
Laptop Freezes when entering WIndows7 if power cable is left connected
Toshiba Satellite P745
Windows 7 Home and Ultimate (same happens with both versions).
My laptop ALWAYS hangs (just before entering windows, on the 'welcome screen') if it is plugged into the AC-Power.
BUT:
if I disconnect the power cable and battery then plug it back in, then its fine.
but the second I switch off or restart or sleep my computer, then it will Hang or Freeze again the next time I switch it back on. (unless I unplug the power cable and plug it back in again) !
This happens every time, regardless if I use the battery or power-pack or both.
I have no idea what is causing this.
i need to unplug and reconnect the power every time.. (otherwise it will hang).
if it hangs, then i need to do a Hard Switch off.. and it ruins my software registrations..
many apps and software need reinstalling every time when I do the hard power off.
I have got a new hard drive; reinstalled windows; bought a new battery and AC-Power Pack.
i have no idea what is causing this.
but the electricity supply to the laptop needs to be stopped or broken or unplugged so that it can start again successfully.
is there any Windows Start-Up log i can view or install to see EXACTLY what part of the start-up process my computer hangs ? coz this might help me find the problem.
- I tried disabling the AC-Adapter and ACPI battery (in the "Device Manager") but this did not help.
- Please let me know if you have any ideas for me.
Thank you
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Marc, I googled, Toshiba laptop freezes on start-up, may because of an incorrectly functioning master boot record or boot configuration. Check the attached links,instruction and guides, Good luck
https://www.techwalla.com/articles/how-t...
http://forums.toshiba.com/t5/General-Tro...
Indice 1
3 commentaires:
i dont think its a Master Boot Record or Windows Software related, because i had this problem on Windows 7 Home edition, and then I bought a new hard drive and installed Windows 7 Ultimate, and i have exactly the same problem.
installing a new windows would have cleared up the configuration and master boot issues.
par
Marc, Windows Start-Up log, link below, hope it helps.
http://www.techrepublic.com/blog/tr-dojo...
par
Thank you again.
But this MsConfig Boot-Log will Overwrite itself every time.
so, i never get to see the log of the failed attempt.
if I reboot without unplugging the power it will hang/freeze/fail and i want to see this boot log.
but to enter windows I need to unplug power again and reboot and the Log that I view is the most recent Successful attempt and not the previous unsuccessful attempt.
par
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 254
