I've swapped the brake switch but now I'm clueless.
Hi
I'm having trouble with my Vauxhall zafia. My tail /brake lights work as they should when ignition is off but when on or turn the key then they are on at all times. I've swapped the brake switch but now I'm clueless. Thanks
2 commentaires
Adam, to answer your question we need more info. year, make, model,engine, transmission and , which switch did you change, after changing switch what is it doing, Any damage,accidents,recent work,etc.
The more info. the better ifixit can answer your question more effectively. Thanks.
par L Pfaff
Hi, Try removing the brake light fuse (is it OK?) and see if it comes on either way i.e. with ignition on / off. With the fuse removed and the ignition on, if they still light then you will have to trace where the power is coming from.
Here is a link to the wiring diagrams for 2001-2004 Opel Zafira. Hopefully yours will be similar and this is of some help.
ftp://toksvaerd.dyndns.dk/Uploads/Bil/Op...
par jayeff
