Aller au contenu principal
Fitness and sleep tracking band that also displays caller ID information when paired with a smartphone app. Released in November 2014.
20 questions Voir tout
My fitbit wristband is peeling off
How can I repair my fitbit wrristband which is peeling off and posing the risk of the fitbit getting lost
Répondre à cette question J'ai le même problème
Indice 4
2 commentaires:
can I get a response please!!
par
The plastic piece behind the info strip has broken and fallen off. Nowhere to be found so i need that plastic piece replaced.
par
Ajouter un commentaire
1 Réponse
Hello, I was having this same issue too. All I did to fix it was use some super glue on the band.
Indice 0
4 commentaires:
OK, i will try that. BUT does Super Glue not burn the actual Fitbit (and leave a white stain mark) since it is made from hard plastic material
par
It shouldn't be visible as long as you put it under the band and don't put too much on. I've been doing this on my fitbit for a while and it hasn't burned. It should be good as long as no contact with the board is made by the glue.
par
Thank you Rob, i will give it a try
par
I am also facing the same problem...i need sol.
par
Ajouter une réponse
Mancane Futwa sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,521
