Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The Brother PT-110 label maker was manufactured by the Brother International Corporation. The model number is UN8173001. Release date unknown.
Why is my device not printing?
The unit turns on, but whenever I try to print a label, nothing comes out of the device.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
1 commentaire
I bought mine in the mid-1990s. About a year later, it stopped printing. I dismantled it and discovered why. A nylon drive gear had spit, and it was spinning loosely in a shaft. I pinched it together and bonded it with super glue. It has worked perfectly since then, and now it's February 2023.
So much for planned obsolescence!
par
Ajouter un commentaire
2 Réponses
Solution retenue
Check to see if the labels are jammed inside. If not, the gears might be worn down and need to be replaced. You might also be out of label paper.
Indice 0
Réponse la plus utile
The PT-110 failure is often due to a broken lever that pushes the feed wheel against the tape. With no tension, there is no tape feed. I have repaired 4 or 5 of these (all my units have had this problem). NOT an easy repair. Epoxy alone won’t hold. If you open the door on the back to replace a tape cartridge, and notice the white lever at the lower edge is “floppy loose”, it’s broken. You should feel spring tension against this white lever as you press the door back in place - which verifies it’s NOT broken. My repair involves disassembly, a thin layer of plastic epoxy to hold it together so I can add a specially shaped piece of spring wire to re-enforce the weak part, then a thicker layer of tougher 907 epoxy to add the strength and hold the special wire in place. Tricky part is to keep the epoxy from getting into the wrong spots.
Indice 2
1 commentaire:
Super write-up which really helped me fix a similar problem on model PT-85. Once you explained tape tension and no tape feed, I quickly diagnosed my issue. Perhaps this solution for the PT-85 will help others. https://youtu.be/XMHB1Tho7so
par
Ajouter une réponse
Kimberly Larsen sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 52
Total : 1,685
