Aller au contenu principal
Pour réparer ensemble - Je crée un compte
CD-Receiver with USB Interface Released in 2015
miswiring message in my stereo.
When powering the radio, there's a stereo message "miswiring, check wiring then power on"?
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
3 commentaires
Sometimes my system would play for awhile then the voice will go out and only the beat will keep playing for a little bit then stop then my deck will say miswiring.. what should i do??
par
My Kenwood did this after 2 years I knew there was nothing wrong with the car so I took the unit apart could not see any corrosion as others have had. I removed the cd mechanism pulling out the ribbon cable reassembled without the cd part and now all working so some part of the cd player became faulty.
par
Check Miss wiring
par
Ajouter un commentaire
5 Réponses
Solution retenue
Try looking on the troubleshooting page under faulty wiring connections.
Kenwood KDC-BT362U Troubleshooting
Indice 0
Réponse la plus utile
I got this error after the unit had been installed for 2 years. I tried many ways to troubleshoot the problem, eventually ending up with nothing connected to the unit except for the black ground, the red power, and the yellow continous power. Still, the message persisted.
I removed the deck and looked at the back. There is a bank of wires coming from the circuit board that had visible corrosion bridging the gap between some of the wires. I scraped this corrosion off, and put everything back together and the system works.
It seems that Kenwood didn't make this marine deck to be around a humid environment. I'm wondering if there is a non-conductive coating (epoxy?) that I could coat this circuit board with to prevent reoccurance. Any ideas?
Indice 2
1 commentaire:
I have the same error message.
I’m going to do this next time I’m at the marina. Thank you in advance if that solves the problem
par
1) miswiring, please check wiring appear on kenwood player
2) pull out the main power connection.
3)press button 3 and 6 at the player then connect back the power
4) when DC error appear, press button 1.
5) when DC1 OK appear on the display, press button 2 and wait till DC2 0 display on screen
6)Turn off the player den turn back on
7) player is ok.. no more miswiring appear.
Here's a link to see how it's done!
https://youtu.be/F7N0hjraN80
Indice 1
1 commentaire:
I’m getting the same message. I have unplugged everything including disconnecting the battery. I even removed the face and held the rest button. It is a single din, no amp and only two speakers. Spent hours trying different things. I’m stumped! Installed it new a a little over two years ago. Any help would be appreciated!
par
mine was faulty cd player removed from stereo now all ok
Indice 0
It's built in
Indice 0
Ajouter une réponse
cristoferj sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 52
30 derniers jours : 286
Total : 87,630
