Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Une tablette de 10 pouces co-créée par Google et Samsung pour la gamme de produits Nexus.
optimizing apps at startup
When starting up it begins optimizing apps and never quite finishes. After repeating this several times over a few days, it now begins the same way but in a short time it blinks and then goes dark.
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
1 commentaire
I found a solution that need no flashing.My s6 edge plus behaved same way.I left like that because I did not want to lose some applications. On the third day it booted normal.
par
Ajouter un commentaire
4 Réponses
Solution retenue
This could be a memory glitch . Holding a bad boot in the memory and booting off the same boot cycle. open the tablet and disconnect the battery then reconnect and reassemble and reboot . This video will help you disassemble the tablet the battery removal is not necessary just disconnect the battery and reconnect .Hope this helps
Indice 2
Réponse la plus utile
If you have Zedge, this is what is causing it.
I had also done other updates and thought it was Android System WebView as it started right after that had updated. Then I read it's Zedge and I've had that program for almost 2 years. I had restarted phone and was again stuck on "Optimizing", but for me each time it has been a good 20 minutes.
I uninstalled Zedge and it started right up, no Optimizing. Thanks for everyone who figured this out!
Indice 4
8 commentaires:
OMG thank you soooo much! It worked and I didn't lose my ring tones! I guess when I'm ready to change them I'll just reinstall then uninstall when I'm finished
par
Yes, Zedge is the culprit, just uninstall, reboot and you are good to go.
par
Worked! Thanks
par
Genius once I uninstalled Zedge the optimizing 1 of 1 was gone this really worked thanks a bunch
par
I uninstalled Zedge and the phone still goes into Android starting 1 of 1
par
Voir 3 commentaires en plus
I disconnected the battery, then recharged completely. The nexus started back up like it should. However, the screen does not respond to touch. Yikes! I must have messed something up.
Any advice?
Indice 0
I know this is a long time ago,but…
Ensure that the ribbon cables you disconnected to replace the battery are fully and properly reinserted.
Indice 0
Ajouter une réponse
David Lovin sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 20
Total : 17,073
