Aller au contenu principal
The C700 is a budget PC notebook released in 2008 by the Hewlett-Packard Company, or HP, through its Compaq subsidiary.
6 questions Voir tout
Question 1:  Why does my laptop keep shutting down?
While using my laptop it continues to shut down mid use. Why is this happening?
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
Student Question
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
The most likely reason for your laptop to shut down mid-use is that the cooling fan has built up debris in it, causing it to be unable to cool the device. This makes your laptop overheat and turn off. I would recommend using canned air to blow out the vents leading to the fan. These are located on the side and bottom of the laptop. If the issues persists, you can open the device up and check to see if there is debris build up in the fan or if it requires replacement. To get to the fan to clean or replace it, follow the instructions in this guide.
Indice 1
Ajouter une réponse
Rob Yule sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 4
Total : 154
