What is this (possibly conductive) gray foam adhesive called and where
I have a theory about touch issues that occur after the glass/digitizer replacement on tablets. I believe that the issues are due to the lack of replacement /reapplication of this gray foam tape that is possibly conductive.
However, I have not been able to find this tape/adhesive anywhere. It would help if I knew the name of the product and the maker too? And is this tape conductive? Is anybody else experimented with this stuff? Am I of the correct thinking that this tape may play a role in touch issues following repairs?
I thank the community for their input!
1 commentaire
I'm on my second LCD digitizer and I think the issue is the foam and/or the tape or lack of. With the first LCD digitizer unit, I reapplied the foam I had removed from the original, and everything worked fine until I closed it up, then had all kinds of blank areas on the touch screen. (yes i'm sure the cable wasn't kinked.)
I want to replace the foam instead of reusing the foam. I think it helps the spacing between the parts. where can I find more foam?
par mamawuh
