Aller au contenu principal
The Samsung NX1000 is a digital smart camera that was released April 2012
Questions au sujet de 22 Voir tout
I can not remove the native objective lens. lens is blocked.
I can not remove the native objective lens. I press the removal button, the lens is not removable. Lens is blocked.
Не могу снять родной объектив. Нажимаю кнопку снятия, объектив не снимается.
Update (12/08/2016)
It is not simple. I have to unscrew the lens before. And I know how to unscrew. However, already half a year can not unscrew the push of a button. I can just strip the threads by following your advice.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Press the button, then rotate clockwise or counterclockwise. Simple.
Indice 0
3 commentaires:
par
You must hold down the button down as you rotate the lens. I do not see how it can be blocked, please explain how it is blocked.
par
I have a similar problem. Camera indicates Lens error oo when power on. Problem with the lens is that the zoom barrel will not turn. I have followed the advice above with regard to the small button and then trying to turn the barrel of the lens but to no avail. I think fffosrab has the same problem, but is just describing his fault as blocked rather than locked or jammed. Watched a video of opening up the lens but not sure I want to do that...
par
Ajouter une réponse
fffosrab sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 90
