Aller au contenu principal
Un ultrabook économique de Fujitsu, commercialisé en août 2012.
How do I remove or disable Sandisk SSD cache
The Sandisk SSD cache in my syste has stopped working so effectively I have a normal HDD without the hybrid (HSSD) capability. I want to replace the hard drive with a SDD but suspect there may be a conflict between the SSD and the Sandisk SSD cache - hence I want to remove or disable the Sandisk SSD cache
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
3 Réponses
Solution retenue
Hi Philippe
Go to "Control Panel", "Device Manager", open "Disk Drives" and right click on "SanDisk SSD i100 32GB"
Then click on "Properties" in the drop-down box that opens - go to the "Driver" tab and click on the "Disable" bar.
This will resolve the conflict between the internal cache (SanDisk SSD) and the SSD drive you installed, and your system should be faster - at least as fast as it was .
Good luck!
Pierre
Indice 1
1 commentaire:
Hi Pierre, thanks for the hint, but actually, I do not see the SanDisk SSD in the Device Manager.
Philippe
par
There will be no problem with the cache. It is impossible for a hdd to operate without cache, so it must be that the system is misreading or something. Just ignore it. Get your SSD, put you os on it, you'll be fine.
UPDATE
The cache is part of the SSHD. Once you remove the SSHD, the cache goes with it. No proplem between anything.
Indice 1
Hi George - thanks for your quick response.
I downloaded the SanDisk SSD Dashboard and it showed that the SSD Cache was not operational. All attempts to re-initialize it failed, so it seems like a hardware failure. I eventually disabled the SSD cache in the Device Manager.
The laptop now operates with the normal disk only - so it takes a long time to boot and is very slow.
I will now replace the disk with an SSD - since the cache is now disabled, there should be no problem.
Indice 0
2 commentaires:
Was your previous drive a SSHD?
par
Hi Pierre,
I also have an UH572 in which I recently installed an SSD. But my laptop is still very slow during bios boot (stays with the Fujitsu logo for minutes before booting normally). I suspects a SSD cache problem. Did you have such a problem ? Where did you download the SanDisk SSD Dashboard ?
Thanks
par
Ajouter une réponse
Pierre Cronje sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 190
Total : 7,728
