G751 Turning On then Goes Off
I recently moved from Australia to United Kingdom, about a month ago I unpacked my laptop for the very first time in seven months (had to be shipped). Battery was dead (fully charged when I left Ozz), so I let it to charge for 3 hours. When I started the PC it will go on for one sec then off again! So I then I hold down the power button for 10 (with adapter unplugged) secs and it loaded up to the desktop, BUTTTTT then a hour later it played up and I had to restart it! It's been like it for months, that it takes me hours to get it started and once on, no problems until it gets turned off . I also now know that, the battery reports to the mainboard something is wrong with it so it powered off, REALLY ANNOYING as it has some 'tech' in it that prevents it from running without a 'all is clear' battery signal. Right now I'm not happy that I spent $2500 for an good PC with bad battery and would like help and support to help to get the replacement part, or whatnot. I'm in the UK also now and hope that doesn't stop things
In the comments you mentioned you purchased a replacement batter and it fixed the issue. Where did you get the replacement battery and how might I get one?
I think i am having the same issue and want to try your remedy.
par Isaac Tucker
Mine got nothing to do with the batter. Turns out that the clipset on the motherboard failed, and unfortunately the clipset couldn't be replaced. And would need to get an new motherboard. End results I sold all the working parts.
You however might have an different results. I can help if you explain more in details to what is happening at your end
par Empire
@empire
Thank you for responding. I am attempting to resolve my issue here: My device will no longer turn on
Any insight you might hold would be appreciated and I thank you in advance.
par Isaac Tucker
