Sounds like the sub connection to the button may have come loose or broken.
This is the actual click button that is behind the one you physically press in.
1. Close the display and turn the computer over.
2. Remove the screw cover located at the center of the base cover.
3. Remove the 9 Screws on the base cover.
4. use a pick to pry the base cover off of the computer, releasing several plastic clips.
Once the back cover is off, you will need to remove the battery from the unit.
Following the removal of the battery, follow the below steps to remove / reset / replace the power board.
Reverse the procedure to re-assemble the PC.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
