Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Western Digital My Passport Ultra est un périphérique de stockage portable USB 3.0 avec des capacités allant de 500 Go à 5 To.
Dropped portable hard drive
I dropped my portable external hard drive. Can I still recover all the files inside my external hard drive?
Répondu ! Afficher la réponse J'ai le même problème
Indice 9
2 commentaires
my WD is dropped and whenever i plug in it asks me to format the Drive G? so is it possible to recovery my files back ?
par
I dropped my My Passport Ultra, and is makes a whirring sound, but does not link up with my computer. Can I recover my data on the disk?
par
Ajouter un commentaire
5 Réponses
Solution retenue
Is this the ssd version or hard disc? If its the hard disc will it power up does it click? If it clicks you can make it work enough to recover data. This video may help
https://www.youtube.com/watch?v=F5Y7Bnia...
Try to be as clean as possible when preforming the task of opening the hard drive . Try to keep dust to a minimum.
Indice 3
5 commentaires:
The power up still functioning but i doesn't blinking and also i hear a noise inside the disc beeping.
par
Can i still recover all the files in my portable external hard drive?
par
Fix for a beeping hard drive https://www.youtube.com/watch?v=7m5cil6K...
Once you get it to work make a copy of your important file odds are it wont last long
par
yea i dropped my one an it has the click of death nowso imtryin to copy as much as i can will this &&^& it up?
par
what if it doesn't click, but lights blink and whirring sound inside, sometimes it lets me unlock but won't go any further
par
It is possible the data can be recoverable, however you need to make sure NOT to plug it in anymore and send it to a Certified data recovery company for help. mobdro app
Indice 0
It is possible the data can be recoverable, however you need to make sure NOT to plug it in anymore and send it to a Certified data recovery company for help. [http://<a href="https://mobdrotvapk.com/">mobdro</a>|mobdro]
Indice 0
My WD passport fell on the floor…now there is a clicking sound and not loading once plugged into device… how can I retrieve files from the external hard drive
Indice 0
1 commentaire:
Did you fix a fix?
par
Hello, today I dropped my 1TB Western Digital MyPassport, the cover came apart and the drive was exposed. It re-assembled just fine, it switches on when plugged in just fine, it sounds how it ordinarily would when plugged in, but is not loading on Windows and is no longer accessible via the Windows File Explorer.
I can select the option to safely remove the USB device however, which is strange. So essentially the OS recognises it in that regard, but the files themselves can't be accessed...
Not sure if this would affect it, but it was nearly full to capacity with only a few GB free.
Can anyone provide advice on what I should do, or know of a good recovery provider in London UK?
Indice 0
Ajouter une réponse
Carl Pastoril sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 28
Total : 95,820
