battery with 100% charge but fails to turn on
Someone could give solution to the problem of: battery with 100% charge but fails to turn on, if it is not with the power adapter.? for RADIUS P55W-C5200X .
There are a few things that could be checked. Firstly, if you can, replace the battery, it may be unable to hold a charge. The second potential problem is that the connectors from the battery to the motherboard are fried, that's a bit harder to fix and will either require a microscope and dam good soldering or replacing the motherboard.
Hola: Tengo el mismo problema con la P55W c5314, aparece el estado de la batería al 100% pero al quitar el adaptador de corriente se apaga la maquina; he probado con quitar la batería y ponerla en el congelador por 24 horas y nada; espero nos den una mejor solución aparte de cambiar la batería. Gracias
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 325
