Aller au contenu principal
Pour réparer ensemble - Je crée un compte
This LG Android device was released in October of 2015. The model number of the device used to create these guides is LG-VS990.
Why is my phone stuck on the LG logo? How can I fix it?
I was listening to Pandora and then my phone completely froze, after awhile it turned off.. I tried to turn it back on again and when i turned it on the LG logo came on and now it wont go pass that screen. It stays stuck on that screen.
Répondu ! Afficher la réponse J'ai le même problème
Indice 7
5 commentaires
im having the same problem have you found out how to solve
par
i am having thesame problem i was browsing the net when the phone was about to receive call then it froze and then reboots and its stuck on bootlogo i can get into recovery mode and do a factory reset after its done it boots up and reboots randomly help please any solution am using a lg g5 ls992 refurbished
par
i have downloaded a new firmware from manufacturer lg but phone still reboots randomly even after installing the new firmware
help any solutiong using refuburbished lg g5 ls992
par
when i try to charge the phone i have replaced battery when i try to charge after powering it off it reboots randomly i thought it was a battery problem j bought a new battery same problem reboots randomly even when i try to recharge am using a lg g5 ls992 refurbished help please
par
@petercarthageabc i have the same problem with my g5 Verizon
par
Ajouter un commentaire
3 Réponses
Solution retenue
this could be a combination of many things. what i would suggest you do is try holding the powerbutton down for 30 seconds to turn on and off. also try taking the battery out for a minute and put it back in and turn it on and see if that helps. I hope that this helps you to fix your phone.
Indice 1
5 commentaires:
Thank you. I tried it but once its on that LG logo screen it doesn't even want to turn off. I left the battery out for 2 days and nothing. I also tried to reset the entire phone but it just wouldn't move from that screen.
par
I have the same issue. It's a known LG g4 device issue.
par
Leave your battery in and the phone turned on till it TOTALLY runs the battery doelwn and goes dead. Then wait 3for 4 hours and plug in the charger but DO NOT turn the phone back on till its fully charged. What your experiencing is similar to a SOFT bricking which occurs when a phone is attempted to be rooted or in apple iPhones case, "jailbroken".
Follow this procedure and it should reset it or if it doesnt, you may need to plug your android phone into a windows based computer, lohg on to the phone manufacturers website and download a new operating system!!!!
par
Same problem with my LG10 I had it to a Verizon store today and they said the phone needs replaced. I still have 4 more payments to complete the contract. I was advised that LG would pick up the monies due if I purchased another LG phone. I told the sales rep I’d have to be dumber than a bag of rocks to get another LG. I have been a Verizon customer since the days of the bag phones and brick phones but tomorrow I’m off to the Sprint store.
Richard Holloway
4/10/2018
par
My own just keep showing the alleh logo over and over again
par
Hi guys. i have LG K20 it did not turn on before it was just restarted. But I opened it and did a check on the board. I removed the power button. Then I mounted it but without the power button and it works now perfect . So all the problem was from Power Button . Try this guys maybe this can help something … Im sorry for my language :)
contact >> sahitplisi9@gmail.com <<
Indice 0
The phone just needed charging. I just never ever let the battery die so this is the first time I saw it flashing this way and hot.
Indice 0
Ajouter une réponse
Araceli sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 44
Total : 32,877
