loud noise during spin cycle
It makes a loud banging noise during rotation of the drum.
Drum is hitting sides of washer because it is out of balance.
Shaking during the high speed spin portion of the cycle in these washers can be caused by several problems including:
Here are some tips that may help you prevent vibration and walking in a front load washer:
These tips may help you resolve your shaking and vibration problem with the washer. Source: Tammy On Another Site.
On the back top right (left if you're facing the machine) there is a round plastic lid-type cover piece that catches and turns to secure itself to the machine by attached to the venting hose which is attached to the drum. When the drum is out of balance it causes the air hose that expels through the plastic cover to become lose and fall off the back of the machine. A technician showed me the hose and how it's connected to the drum during a repair. You do not have to take off the cover of the entire machine to place the cover piece back on. You simply need to pull the machine away from the wall so you can get access to the hose with your fingers. Pull it out as far as it will go, which is only about a 1/4". Take the cover lid with one hand and slowly place in on the hose, turning gently so as not to push the hose back in. There is a groove in the lid which secures to a slight lip at the end of the hose. Any time you hear the drum becoming slightly unbalanced, just feel back to the cover piece and turn slightly to be sure it remains secured.
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 12
Total : 8,847
