Aller au contenu principal
6ème génération de l'Apple iPhone, annoncé le 12 septembre 2012. La réparation de cet appareil est similaire aux précédents modèles et nécessite des tournevis et des outils pour ouvrir et faire levier. Disponible en GSM ou CDMA / 16, 32 ou 64Go / Noir ou Blanc.
20 questions Voir tout
What May Be Causing iPhone to Not Stay On?
I got an iPhone 5 from a friend, and it has one small issue. It has a dent on the back, which is right about where the battery connector would be, but not over the battery itself. Though this big dent is over the logic board, the phone still powers on when you hold the power button or plug it in, but it will shut down after about 3 seconds of being powered on. If you plug the phone in, you see the Apple logo for three seconds, it goes black, then the cycle starts over. I'm going to open the phone and make sure the battery connection still looks sound, but I'd appreciate any suggestions on what to fix or what could be going wrong. Thanks!
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
1- Bad battery. Get one from iFixit. If you cheap out you'll be back to square one very very soon. DON'T pry against the board to remove this or any battery.
2- Battery disconnected.
3- Missing or bad gas gauge (tiny filter located between the battery connector and the metal shield next to that connector).
4- Corrupted software and DFU restore requires to fix it.
5- ALL OF THE ABOVE - yes sometimes it can.
Indice 2
1 commentaire:
Okay. I can get an iFixit battery if I need to, but first I'll try DFU mode and reconnecting the battery on the logic board.
par
Ajouter une réponse
Jake sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 75
