Washer door will not open and machine will not power ip
Washer shut off and top loading door locked.. Cannot get it do anything. Have checked breaker
@hotshot , Tommy, Unplug machine for 10 min. to see if it resets, plug in and try. Try plugging machine into a different receptacle.
Main reasons a washer will not start.
1. Power breaker off, washer not plugged in.
2. Lid switch faulty, door switch faulty.
3. Start switch and or timer faulty.
4. Washer motor faulty.
5. Main control board/user interface,
faulty or shorted.
Unplug machine, open machine Link #1 and check all wires/plugs for loose/damage/burnt/pinched/corrosion repair anything thing found and try machine. If not comfortable working on your machine have a good Tech. have a look, diagnose and estimate repair.
Find below a few links below that may help, especially if you can get it to go into diagnostic mode. Good luck.
https://www.youtube.com/watch?v=-Hnnda0F...
https://www.youtube.com/watch?v=nttHsAX2...
https://www.youtube.com/watch?v=Lxs5ga4u...
THANK You … my clothes were lock in the washing machine for 2 week`s then my cousin sad look up the machine on you tube they got everything on you tube , i look at the 5 links and one of the had a machine that was close to mine and it showed how to open it and it showed how to find the codes for my machine . Thank `s again . Now it`s off to the laundromat…
Also - try flipping the breaker off and on. That works as well!
Dernières 24 heures : 12
7 derniers jours : 61
30 derniers jours : 256
Total : 15,379
