Samantha Bazant , Look into the charge port with a flashlight, look for dust/lint/etc. and blow the port out or very carefully pick it out. Also look for any damaged terminals if you see one bent very carefully straighten it with a tooth pick. Also remove the battery and clean the camera's battery contacts with a pen with eraser on the end or a long Qtip dampened with 90% Isopropyl Alcohol (pen eraser's have a little more grit to them and polish up terminals well), blow out dust, debri, etc. when done cleaning, insert battery and try.
Still not charging correctly, wiggle the end of cable to see if the camera charge port is loose, not if light flashes, etc. If port is found to be loose/bad, this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the camera to check the charge port if need be and will also post a link showing what is involved in repairing a mini USB attached to the a motherboard,(not your device, just an example). Good luck.
Remplacement de la carte mère du Nikon COOLPIX P500
https://www.youtube.com/watch?v=Ov-HACi9...
A voté
Annuler
Indice
4
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
1 commentaire
Finally, after enduring my on/off again Nikon problem, I decided to spend money on two new Nikon-compatible batteries. And the results are: THIS WORKED! My camera doesn't shut off in < 60 seconds. I think the other batteries I bought were inferior knock-offs that eventually became so swollen, they became hard to remove from the battery bay inside the camera. AVOID OVERCHARGING your batteries, folks! Order BM Premium 2-Pack of EN-EL5 Batteries from Amazon for $12.99 and you can thank me later.
par Brian Brewster
