Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Mini-lampe torche de Maglite utilisant une seule pile AAA.
Trouble opening ro replace battery
I am trying to open the bottom to replace the battery but it won't budge. Any suggestions?
Répondre à cette question J'ai le même problème
Indice 4
2 commentaires
I have this problem too.
par
Same problem! I have tried everything to get the end cap off two pairs of pliers, the hairdryer thing some I cannot get it to budge!!
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
You can try heating the end with a hair dryer, this may help loosen the battery cap. It is possible that the battery has leaked and that is making the flashlight hard to open. The heat trick should help with that. If the battery has leaked, try cleaning the interior with vinegar and some cotton swabs.
Indice 1
Maybe use some WD-40 and squirt in near it and let it soak down. Have you tried some pliers of grips to remove it?
Indice 0
2 commentaires:
Heat the top battery cap while insulating the bottom then put the bottom into crushed ice using a pot holderto hold thw hot cap then use 2 pair of pliers or grips to open
par
I tried with 2 pairs of vise grips and it won't budge I have no idea what to do.
par
Ajouter une réponse
sethsmom0618 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 99
Total : 17,647
