Aller au contenu principal
Coffee brewmaster released in 2013. The Keurig K40 is a k-cup compatible coffee maker.
20 questions Voir tout
leaking water out bottom of coffee maker
my keurig k40 is leaking water from the bottom
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
3 Réponses
There are several possible causes.
The easiest to check and fix is that the holding tank is cracked and leaking.
Its also possible that the needle is clogged up with grounds, you can use a paperclip to clean out the needle.
It could also be that something is broken inside the which is difficult to diagnose without taking it entirely apart.
Indice 0
The bottom needle broke off with the plastic it it modes to.
Is there a replacement part available?
Indice 0
There are some easiest ways to fix this problem:
Faulty O-Ring
Inspect The Water Reservoir
Keurig Needs To Be Descaled
Broken internal Part
you can see all the solutions on this guide How to Fix Keurig Leaking Water/Coffee From Bottom
Indice 0
Ajouter une réponse
lcm348 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 4,851
