The dryer is working but not heating
the dryer is working but not heating
@minielly ,Rob, Are you getting 230 volts to back off dryer. Dryer can run on one leg of power with no heat.
The thermal cut-off, high limit thermostat are the most likely causes of the no heat problem, located on the side of the heater housing behind the lower access panel. They can be checked for continuity if a meter is available. If test OK may be a faulty heating element. Use the links below for more info. on diagnosing and testing, last link is the service/repair manual. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=wVTBrGMq...
https://www.youtube.com/watch?v=5NbYdKCb...
Here are a few possible reasons why this may be happening:
@sami786 your habitual linking to the same address is considered SPAM. You do NOT want to do that. You can add that link to your About page and refer to it, but you CANNOT use it on ANSWERS. Also, chatbot's do not provide good answers. Yes, the grammar is good but they are at best scratching the service of a question. Do not rely on it to provide good answers to specific questions.
The link has been deleted from your answers as a sign of good faith. Do not disappoint.
Anyhow, those are the rules to comply by. NO MORE LINKS to the place!
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 40
Total : 13,562
