What could cause new keyboard malfunctioning
Changed keyboard because of beer spill (a few month ago) and the right side of the new keyboard is not working. When I connect an external keyboard as I've been doing to get along, everything is fine. Thks for any help.
4 commentaires
Really a new keyboard or a used one ?
par lemerise
Absolutely. direct from Apple
par Pierre Terrien
Since it's a liquid spilled MBP check for corrosion inside the keyboard socket (where yo connect the kb) and if you find any clean it with a toothbrush and isopropyl alcohol. If that does not work then the logic board could be affected or the new keyboard could be faulty. Bonne chance Pierre...
par lemerise
Tks to both of you.
No apparent corrosion, so I re-seated kb connections at both ends and everything is OK.
Merci and best wishes!
par Pierre Terrien
