Accidentally choose factory reset!
How do I recover files & photos phone after factory reset?
You can but it would cost you thousands of dollars in advanced data recovery. Unless your phone was backed up to a google account your photos are gone without paying out big money
Hello
In settings "back up and restore data"....is where you would go and
It should restore almost all of your info... but you would have to
have turned on the " back up my
data" feature...if you did, set your
phone up like in the beginning and
Go to settings, touch "back up my
data" and It should.
However, if you never set it up
this is not an option. You will have
to start over...this time don't forget to turn on your "back up
my data" feature.
Also if you have a memory card in
now...check on your memory card.
Hope you get it all worked out!
AK
It doesn't work like that. Photo's backup has to be enabled separately.
Assuming you were using Google Photos app, and you did turned on the 'backup and sync' feature for this app, you can simply go to https://photos.google.com and your photos would be there.
Alternatively, if you had an SD card in the phone, and were storing photos, a reset would not have wiped the photos there. You would have immediately seen those using the Google Photos app.
If neither of these were done, unfortunately, it isn't possible without thousands of dollars of forensic recovery tools to get back your photos.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 13
Total : 262
