Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La manette sans fil Xbox One 7MN-0001, fabriquée par Microsoft, est généralement utilisée avec la console Xbox One, mais elle peut également être utilisée avec un PC.
Broke LT and RT holders how do I replace it?
I have provided two pictures, the blue controller is the one that I'm trying to fix. The dissasembled controller is the one I'm using for the RT and LT.
I want to remove the Trigger holder from the controller but don't know how to do it.
It's the metal piece holding the Triggers.
I need help guys.
Répondre à cette question J'ai le même problème
Indice 3
1 commentaire
Hello, my RT button on my Xbox One controller is not working correctly. When I get on NFS the car drives by its self.
par
Ajouter un commentaire
6 Réponses
Réponse la plus utile
https://www.youtube.com/watch?v=NZp8Rcik...
Indice 2
1 commentaire:
Thanks for that
par
Hello @imzai,
There is no photos as I can see, did they upload correctly?
Well, I provided a few IFixIt links that may help
Remplacement des vibreurs des gâchettes de la manette sans fil de la Xbox One
Remplacement des boutons de la manette de la Xbox One sans fil
I hope these help!
Thanks,
Keegan
Image Xbox One Wireless Controller Model 1537 Vibreurs des gâchettes
Tutoriel
Difficulté :
Difficile
15 - 20 minutes
Image Xbox One Wireless Controller Model 1537 Boutons
Tutoriel
Difficulté :
Difficile
30 minutes - 1 hour
Indice 1
3 commentaires:
I have edited my post, I've uploaded the pictures, what I mean to to remove from dissasembled controller is the metal stick holding the triggers.
par
Okay I see, so if you look back in to the link Remplacement des vibreurs des gâchettes de la manette sans fil de la Xbox One it shows how to remove the moters. So, I think by the look of the photos its soldered to the board. Can you confirm this?
par
You have to press the small part of the metall pin then it comes out on the other side where you can grab it with pliers / tongs / nippers and pull it out gently.
You have to be very carefull, else you destroy the trigger or the frame.
Indice 0
I need a LT trigger spring
Indice 0
How to take this off lt button
Indice 0
1 commentaire:
Same here, my rigger holder is broken too
par
My left triggers has came out of the socket please help
Indice 0
Ajouter une réponse
J Angel sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 66
Total : 30,835
