How do I change front struts
How do i change front struts
Front struts are easy on a caravan and do not require a front end alignment when done as long as you don't change the tie rod ends when you do it . There are tow bolts holding the strut at the bottom and 3 on top accessed through the engine compartment. If your only replacing the strut then you will require a spring compressor as you need to compress the spring to remove it safely This video will help
https://www.youtube.com/watch?v=ns_IzhfJ...
Hope this helps
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 4
Total : 95
1 commentaire
jms_skw ,You are putting your question in the answer box, it would be best for you to repost all vehicle details year,make,model, etc and your question/problem as a (question)! This will be seen by more volunteers and may assist answering your question better.
par L Pfaff
