Heater alternately blows hot and cold air.
When heater select button is on hot fan alternately blows hot and cold air.
This could be as simple as your control not properly clothing or opening the valve on your heater core , to a malfunctioning and leaking heater core. Also make sure you do have enough coolant in your system. Your cooling system might need to get flushed and/or bled. Again there are multiple things but I would start with the fluid, check connections of the hoses, check the heater core. Good luck and let us know what you find.
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 12
Total : 4,442
