Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Dyson AM07 est un ventilateur tour sans pales sorti en 2014. L'AM07 utilise la technologie « Air Multiplier » pour créer un flux d'air fluide sans utiliser de pales visibles.
fan not oscillating back and forth
What's wrong and how do I fix it?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
I have the problem too, it is not oscillating.
par
Ajouter un commentaire
2 Réponses
Solution retenue
mkoch, If it is new, did you remove the tape, from the lower base body split section, if not remove before turning on any more or damage to internal gear could occur. Recheck that the fan is still assembled correctly and locked in correct position. Install new batteries in remote and try. If all looks good and still under warranty return for repair/replacement/refund as there may internal damage to oscillating gear. See below links, your manual and Dyson support site.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.manualslib.com/manual/888752...
https://www.dyson.com/support/am02/am02-...
Indice 7
2 commentaires:
So simple, duh, I forgot the tape. But it doesn’t show that in the setup instructions.
par
I need help in opening the remote. I've had three people look @ this remote. Pls help!!!!!!!!!!!!
par
It would be more helpful if the tape that has to be removed was an obviously different colour rather than white the same as the oscilating plinth - ie ... make it idiot proof - it took me a while to work it out as well lol
Indice 0
Ajouter une réponse
mkoch sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 31
30 derniers jours : 141
Total : 50,909
