Aller au contenu principal
Un smartphone Android produit par Huawei et mis sur le marché en avril 2015.
Can I fix a broken screen at home?
I have broken the screen of my Huawei P8, quite harshly... Is it possible to fix this myself(at a low cost) instead of sending it to a professional repairplace? If not, do you know where I can go to fix this? And how much it will cost me?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Hi Inga,
It's work, it would feel challenging to a first timer - but it's not something you should shy away from if you feel up to the task. The monetary savings can only be compared to what your local repair shop would charge you.
Here are some things to consider, an electronics tool kit such as the one sold by ifixit is very helpful, and at a minimum, a screwdriver kit and some kind of prying tool is needed. This guide below is for the P8 Lite, but it will give you a good idea of the work involved to take it apart:
Huawei P8 Lite Teardown
ifixit also sells the screen replacement you need at $55+shipping:
Huawei P8 LCD and Digitizer
If you have absolutely no tools, it might be cheaper or close to same cost to pay for repair service locally. However, the toolkit is forever, and so is the experience.
I hope this helps to give you a general idea of what it entails
Image Replace an LCD and Digitizer compatible with Huawei P8. Features a 5.2 inch IPS-NEO LCD 1080 x 1920 pixel display.
Produit
$9.99
Indice 1
Ajouter une réponse
Inga Katrine Vold sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 1,307
