Do I need to remove the logic board to replace the hard drive cable?
I have an iMac that isn't recognizing the internal hard drive at all. I can plug it into an external adapter and see it (although it only shows up in Disk Management, not in Finder) so I am thinking the problem is the hard drive cable.
I don't see any guides on replacing it, but it appears to run under the logic board, so am I going to have to remove it first? If so, can I take it out without messing with the power supply?
Hi,
To be 100% sure the Hard Drive itself is ok, you should try to boot your mac with it (even by plugging it externally). Here is more info about it: https://support.apple.com/en-us/HT202796
Also, it seems that to remove the data cable you do have to remove the logic board, as mentioned here: iMac Intel 20" EMC 2266 Hard Drive Data Cable Replacement
Hope that helps!
par Paul Jacques
