Hi @taylor_haynes ,
I assume that you replaced the digitizer and it is still not working correctly. Is this correct?
To try a firmware update, connect a USB mouse via an appropriate OTG (On the Go) adapter cable. (This is just an example to show what it is, not a recommendation for the sellers. There are others that may suit you better. Just search online. Also note that an OTG cable is wired differently to a 'regular' USB connector adapter cable i.e. micro male USB to standard female USB cable
(click on image to enlarge for better viewing)
Use the mouse to navigate through the tablet in lieu of the touchscreen.
If you need to use a keyboard, you can use a USB keyboard the same way using the OTG adapter, (be aware that for some reason not all USB keyboards will work this way, don't know why).
Obviously you'll have to disconnect the mouse to connect the keyboard. (or try a BT keyboard, once you have enabled the BT connection with the USB keyboard and use it with a USB mouse at the same time. Haven't tried this myself so don't know if having both connected works or not - just a thought).
Also take note that you'll have to keep check on the battery level as the USB devices (BT?) will draw more power from the tablet and you cannot run it on the charger at the same time as the tablet is changed from a USB 'device' to a USB 'host' when the OTG adapter is connected.
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
