Aller au contenu principal
The Chevrolet Malibu is a mid-size car manufactured by Chevrolet from 1964 to 1983 and since 1997. The Malibu began as a trim-level of the Chevrolet Chevelle, becoming its own model line in 1978. Originally a rear-wheel-drive intermediate, GM revived the Malibu nameplate as a front-wheel-drive car in 1997.
How To Replace MAP Sensor?
I'm a pretty handy person. I've been getting the "SVC ESC" error message and the check engine light on my 2012 Chevy Malibu LT 2.4L, along with rough engine idle. After doing my homework I need to replace the MAP sensor. I figure easy enough, problem is I have a vague idea where it's located. I've scoured the net trying to find something solid whether a youtube video or forum with some sort of way to pin point or show me the location and a possible how to access the place if not easily obtainable.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
pierce2784 @lpfaff1 has answered the MAP however to address the "SVC ESC" error is a different story . This stands for service electronic stability control. this could be caused by a host of things. If you have access to a OBDII with ABS functionality you will find it a great asset in diagnosing the problem . If you have an ABS light on at the same time it could be anything from dirty tone rings to metal filings sticking to the sensor head. It can also be the ABS pump not functioning properly or something as simple as the yaw sensor. Some cars have this located under the passenger seat and occasionally if something gets jammed in under the seat it can affect how it works. It can also be caused by bad struts, a loose swaybar ,bad wheel bearings , seized brakes .or a faulty steering rake. Its hard to narrow it down without a proper inspection . Hope this helps
Indice 2
4 commentaires:
Thanks @jimfixer , I was reading up on the SVC ESC error and you beat me to it, good assist, thanks again.
par
@lpfaff1 always happy to help out . I kinda wondered if you were finished there or not .
par
@jimfixer , Some times I get reading and one thing leads to another(time flies). thanks again.
par
@lpfaff1 Watch what your answering tonight theres student out on the forum . I just trolled one by accident Why can't I connect to my printer?
par
pierce2784 , replace the MAP sensor. link below may help, 2nd link is the replacement sensor to aid in what to look for. See below for SVC ESC error info. by Jim. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=OMmrjtDg...
http://www.jcwhitney.com/1997-2012-chevr...
Indice 2
Ajouter une réponse
pierce2784 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 20
Total : 7,735
