Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Annoncé en juillet 2015, voici le téléphone phare de Motorola. Il est doté d'une caméra de 21 mégapixels, d'un écran PS TFT LCD Quad HD de 5,7 pouces avec une résolution de 1440 sur 2560 pixels. Numéros de modèle : XT1570, XT1579, XT1575 and XT1578.
Power Button Not working after screen replacement
I recently changed the screen on 2 Motorola Moto X pure edition, Because it was cracked but after replacement the power button doesn't work anymore. I wonder if that could be a defect on the screen I bought. Or if I did something wrong. I followed a online guide changing everything. And Both screen bought from the same seller won't power on. It does light up when I charge just not able to tun it on. what do I have to do ?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
Did you ever figure this out or solve it?
par
Ajouter un commentaire
3 Réponses
Solution retenue
I had the same problem - my power and volume buttons stopped working after replacing the battery.
Refer to step 8 here, specifically the 2nd screenshot (2 of 3). I had to reseat my power/volume flex - I did not have to reseat the connector to the board.
The 2nd screenshot shows a cable that could have come loose. Mine was glued down and taped, but had still come loose (probably while heating the phone up to take the back plate off).
I used long thin pliers to peal the clear tape, reseat the flex, and put the tape back on again. The phone works great now!
Indice 2
1 commentaire:
Same problem and same resolution, but with Moto Z Force Edition. Thanks!
par
there is a small rubber cover on the upper left hand side of the back plate after you close the phone back up. If you remove the cover it exposes a ribbon cable and connector the you can push to connect back to the main board. There is another one near the bottom for the same purpose to connect the battery.
I found and reconnected the one near the bottom but I missed the connector in the top left. The phone exhibited similar behavior: screen lights up when plugged in but power button doesn't respond. Hopefully that is also your issue. Hope that helps.
Connector locations
Indice 1
I have same problem,after screen replacement, but i dont know where is this place. Where is 2 from 3 screen? Please help.
Indice 0
Ajouter une réponse
matheusphillipemuniz sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 35
Total : 4,574
